VRaySoftBox problems
  • VRaySoftBox problems
    Hi, here are two issues I'm having with VRaySoftBox map
    Windows 10 Pro 1709, running 3ds Max 2018 Update 2 due to project specification (happens also on Update 3 and Update 4), tested on V-Ray 3.60.03, 3.60.04 and Next 2.
    1. Occasionally mouse cursor gets stuck in the gradient box while adjusting flag position. Alt+Tab from 3ds Max and then Alt+Tab back to 3ds Max usually "unsticks" mouse cursor. Not a deal breaker.
    2. I cannot see gradient flag color editor dialog. Tried resetting 3ds Max, reinstalling V-Ray, repairing Visual C++ and .Net runtimes, LoneRobot script does not detect this dialog, so I cannot bring it back. Also tried Alt+Space with no luck.
    Any insight would be highly appreciated.
    Hello!
    Thank you for reporting this issue. It's now logged in our bug tracking system with high priority. It seems the gradient sliders are in fact not working at all.
    As a workaround, you can use max script to access the gradients adequatly (you won't see the change in the UI but the render will respond to it). For each gradient slider, there is a float array variables for the gradient positions and point3 array for the color.
    I wasn't able to reproduce the mouse cursor lock but I hope it will be fixed with the above issue. It will help us if you can give us more detailed description about it.
    Margarita
    Margarita Stoeva | chaos.com
    Chaos QA (V-Ray for 3ds Max)
