Not getting camera projection on light texture
  • Not getting camera projection on light texture
    Hi guys,
    We need to camera project a texture to use in the a vray light's texture slot. We tried a couple things with no success:
    - set the map to environment/screen mapping mode
    - use the camera map per pixel map
    Any ideas on how to get that working?
    Hristo Velev
    MD/FX Lead, Bottleship VFX
    Sofia, Bulgaria
    It's a showstopper problem for us on this project, would be great to know if that's something that can be fixed. Thanks!
    Hristo Velev
    Sofia, Bulgaria
      The Camera map per pixel seems to have quite limited functionality and I don't think it can be used in this scenario. I tried several approaches including Scanline and max lights setup but it doesn't work.
      Maybe it would be possible to get what you want using Camera map per pixel in conjunction with a V-Ray light material or a regular material with mapped Self illumination slot ?
      Tashko Zashev | chaos.com
        Thanks for getting onto this! Self illuminated won't really help, because we're illuminating environment fog, and the render times would become prohibitive. Even without camera map per pixel, using a map in environment/screen mapping mode should work, and it's not - looks like the light doesn't respect this type of mapping. It would be great if we had control on the UVs the light is using - maybe pick them up from an object or something?
        Hristo Velev
        Sofia, Bulgaria
          Can you give us an example setup so we can investigate further relying on your specific scenario ?
            Here' s a scene:
            https://www.dropbox.com/s/x7t18qog56...018_4.max?dl=0
            V-Ray 3.60.03, Max 2018.4
            You can see how the light is not using the environment/screen UVs.
            Fixing that would be great, hotfix would be awesome. Giving us control over the UVs would be even better, for the longer term.
            Tried in VRay RT CPU - the bug is not there, the light does respect the env/screen UVs. But it is not illuminating environment fog when texture is on, so we can't use it Not sure if that's a bug or a limitation.
            Hristo Velev
            Sofia, Bulgaria
              Have you guys tried this?
              http://www.rensheeren.com/blog/osl-cammapscale/
              Kind Regards,
              Morne
                Hi Morne,
                Yeah that's not working either - it's not a problem with the camera map per pixel but the light not getting the UVs correctly it seems.
                Hristo Velev
                Sofia, Bulgaria
                  Originally posted by glacierise View Post
                  Here' s a scene:
                  It does sound like a bug that we can fix, I'll forward the case to our developers and will keep you posted for any news.
                    Great, thanks!
                    Hristo Velev
                    Sofia, Bulgaria
                      Have you tried placing a plane at the appropriate location, map the texture onto said plane, then render-to-texture and use the resulting texture as the texture for the light?
                      Software:
                      Windows 7 Ultimate x64 SP1
                      3ds Max 2016 SP4
                      V-Ray Adv 3.60.04
                      Hardware:
                      64GB RAM
                      DxDiag
                        Unfortunately this is not at all easy to implement. Will see what can be done about it, but for the moment, the workaround suggested by Art48 with baking the texture should work.
                          Ok, we'll try this out, thanks. Cool workaround, should have thought about it
                          Hristo Velev
                          Sofia, Bulgaria
