forestpack areas - boundary checking - edge does render AO of the cuttet object
  • forestpack areas - boundary checking - edge does render AO of the cuttet object
    hello,
    vray 3-60-04 shows the AO of the edge cuttet object.
    so far it is all right, the objects get cut at the edge, but its wrong that i see the AO of the rest of the object that got cut away
    problem of FP 5-4-0 or Vray?
    you need to activate work with transparency on vraydirt material
    Surrealismo
    https://www.facebook.com/surrrealismo
      big thanks, that did the trick !
