Dark Boxes
  • Dark Boxes
    I posted this over on the NEXT Beta forum, but I haven't gotten any help. One machine and using Bucket BF+LC. I am getting dark boxes randomly across my image. This was a DR issue years ago, so I don't know why it is happening now.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      Is the light cache generating fresh everytime or is it accessing a saved cache that the DR nodes cant read?
      e: info@adriandenne.com
      w: www.adriandenne.com
        I am assuming fresh since I am not using DR.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I've replied in your original thread this morning. There is no reason to create 2 identical threads.
          Peter Matanov
          Chaos
            When I have a deadline and I need help, I felt that there was a need for another post.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              You are using a beta build in production? #YOLO much?
              Software:
              Windows 7 Ultimate x64 SP1
              3ds Max 2016 SP4
              V-Ray Adv 3.60.04
              Hardware:
              Intel Core i7-4930K @ 3.40 GHz
              NVIDIA GeForce GTX 780 (4096MB RAM)
              64GB RAM
              DxDiag
                No, never!
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  I've had similar Problems in very rare cases when using Adaptive Lights at low settings (global switches) but with 3.60.04. Does it help if you set it to full light evaluation?
                    I used all the defaults. Can you elaborate?
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Yes it happened to me even with default settings. In the render setup, v-ray tab, if you set the global switches to advanced or expert mode. At default adaptive lights are set to 8, which might not be enough in some cases. If you set this to full light evaluation, does it prevent those blocks?
                      But still, this is for 3.60.04, havn't tried on v-ray next yet.
                        Thank you, I'll give it a try.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Getting weird dark blocks all over my animation with the adaptive lights default setting in version 4.02.04. Why is this still an issue?
                            Because everytime you want to make something smart in software development it occasionally fails and is dumb.
                            Software:
                            3ds Max 2016 SP4
                            V-Ray Adv 3.60.04
                            Hardware:
                            64GB RAM
                            DxDiag
                            • #15
                              I am getting these bad in my element passes. I think it is the same thing going on but on my reflection and specular passes.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
