Nvidia AI Denoiser Error
  • Nvidia AI Denoiser Error
    In 3ds Max 2019 I am getting an error with the Nvidia AI Denoiser after completing one successful rendering. In 3ds Max 2018 I don't receive an error, however, the Nvidia AI Denoiser will not complete after the first successful rendering attempt. The Attached Image shows the error I receive when rendering is 3ds Max 2019.
    Can you tell me what is your graphics card and driver version? Also does it happen on any scene, or just this one?
      Quadro M5000, 391.58. I tested a couple a different scenes.
      1) Scene was created with Previous Version Vray 3.60.04 and 3ds Max 2018 or prior, Heavy Scene, lot of High Poly Count content, no vray proxies, Large Scene File Size 4gb, High Resolution Rendering 6912x3456 - One Successful Rendering, Subsequent attempts error out.
      2)
      Scene was created with Previous Version Vray 3.60.04 and 3ds Max 2018 or prior, Heavy Scene, High Poly Count, Vray proxies, medium size scene file size 400mb, Moderate Resolution Rendering 3648x2432 - One Successful Rendering, Subsequent attempts error out.
      3) New Scene 3ds Max 2019, Default Vray Next Rendering Settings with the exception of Vray Denoiser w/ Nvidia AI Denoiser and Resolution, Feather Weight Scene (One Box, Vray Plane, Vray Dome Light, Vray Physical Camera) - Several Rendering Image Passes will occur during rendering(+15), effectsResult element will appear in frame buffer, several passes will continue after and when complete I will get a black Frame Buffer or Denoiser Error.
      4) New Scene 3ds Max 2019, Merged Rendering Setting from Scene example #1(Resolution 6912x3456), Feather Weight Scene (One Box, Vray Plane, Vray Dome Light, Vray Physical Camera) - Renders 2 Image Passes, effectsResult Element Appears after Passes and Bloom Apply completes, No Denoiser errors, I can render multiple camera views without having to close out of 3ds Max.
        Hi Guys,
        I think I am having a similar issue? Purchased my personal V-Ray Next upgrade this past Saturday and am now just able to download and test it out and I get this problem with both V-Ray Next CPU and V-Ray GPU Next either full render or during IPR.
        I have two GTX Titan Blacks, I've downloaded NVidia's latest driver, I'm running Max 2018, I also installed the latest Nightly build of Phoenix FD as my previous full release was giving me a DLL error on starting Max.
        I've rebooted multiple times since the NVidia driver update hoping it might be that. I also noticed that CUDA is giving an error in my second screenshot.
        I can't wait to get this working at home as the past few days at work with V-Ray Next has been a real pleasure (on an old Quardro m4000 I believe at work so I'm super sad my Titan Blacks are being weird with this latest version), you and the team have outdone yourselves!
        Thanks very much for your help!
          Hey Guys,
          A follow up, I wanted to let you know I was able to resolve the issue by rolling back my Nvidia drivers.
          It was a tedious process this morning but I went through and installed every previous Nvidia driver one by one until finally one worked all the way back from December.
          The first one to work was : Version 388.71 – WHQL | Release Date: Wed Dec 20, 2017
          I hope this saves the team some time and helps others that might have a similar problem.
