Do you have any third party plugins like IToo ForestPack or RailClone - they need an updated version to work with V-Ray Next. If that is not the case - then when Max crashes it should create a crash dump called 3dsmax_minidump.dmp in your temp folder (%temp% in your windows explorer) - could you attach it here or send it to support?
I do not have the third party plugins you mentioned but I was using a frame buffer plugin called VFB 2.0. Do you think that could have caused the crashes?
