VRay NEXT - no Low Thread Priority, computer gets frozen during rendering.....
  • VRay NEXT - no Low Thread Priority, computer gets frozen during rendering.....
    The Low Thread Priority checkbox has disappeared off the UI, so now, when I do renders, my computer freezes during ADV rendering and I've no way of choosing Low Thread Priority to overcome that ??
    Am I missing something here ?
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    I thought Vray NEXT would have this sorted somehow, it was one of the main reasons we crossed to NEXT from 3.6 as my dual XEON alway became unusable during rendering and all the workarounds i tried that Vlado posted did not do the trick. Moreover, setting projects affinity to less cores got always reseted after a while...terrible.
    I really hope to see some solution in this regard. Things got really fu**ed up after last years summer windows update. Before this never happened.
    Martin
    http://www.pixelbox.cz
      Well for me it seems to have gone backwards, with 3.6 I was using an i7 and Low Thread Priority meant I could continue using my machine during rendering.
      I've now gone to i9 machines, and these feel wretched without Low Thread Priority......I think it's what's also causing my Chrome Remote Desktop to bomb out (quite simply, too much resource).
      Yes, this needs to get sorted, PDQ.
      Jez
        weird stuff is the fact that if you take away few cores from the job in the affinity settings, youll be back to full core usage very soon for no reason...it just switches back.
        seeting up the environment variable doesnt work for me also and neither does the other workaround thats flying here somewhere.
        You shouldnt be feeling such hickups when using progressive. It only seems happen to buckets.
        Martin
          Hello,
          The Low thread priority is now always ON for regular renders started from Max and OFF if you submit through Backburner and on render slaves.
          We are setting the priority to the lowest value possible for Windows and can't do much beyond that.
          A possible workaround is to use lower number of threads - here are some ways to do it:
          https://forums.chaosgroup.com/forum/...912#post976912
          Yavor
          Yavor Rubenov
          V-Ray for 3ds Max developer
            I set DR to be on and now my main computer grinds along very slowly. I'm not sure I understand the logic and why this would be implemented as I now have a problem I didn't have previously.
            Jez
              Thanks Martin, I can confirm that when using Progressive Rendering, Distributed, the lag is no longer there.
              Jez
                The low thread priority OFF applies only to the render slaves - your main machine is working with low thread priority ON.
                Yavor Rubenov
                  Hi Yavor,
                  So is this a bug ? Since having LTP ON for Host (DR) and buckets still causes lag on the Host machine..... will this be addressed in an update/fix ?
                  If I switch to Progressive rendering, DR on both machines, I suffer no lag.
                  When I render DR but don't use the Host pc, I have no problems with lagging (of course.....).
                  The link you gave earlier, regarding setting the number of threads, please can you explain better how / where to do this. The instructions Vlado gives are not clear for me where to find all of this (I've looked under Task Manager) - this is what he says;
                  "The correct way to do this is to set the priority of the 3ds Max process to "Below normal" (or lower if you wish). Changing the processor affinity has never been the proper solution. You can also set the VRAY_NUM_THREADS environment variable to set the number of threads for V-Ray to use, or alternatively, change the renderers.current.system_numThreads parameter from MaxScript."
                  Many thanks.
                  Jez
                    As I said when we set LTP to ON - we set our threads to the lowest thread priority so we have not much else to do. Once we set the priority - it is the operating system that manages the threads and decides which to run.
                    To set the priority of the 3ds Max process from Task Manager:
                    Task Manager -> Details -> Right click on the 3dsmax executable -> Set priority.
                    With the environment variable you can specify the num threads for all Maxes and all scenes. The easiest way to do it is from the Start menu - start typing in the search "environment" and you should see "Edit environment variables for your account". From the dialog you can add a variable to your user's variables - with name VRAY_NUM_THREADS and value the number of threads you want (you could start with one less than the number of threads of your CPU). Keep in mind however that when setting/changing environment variables you need to restart 3ds Max.
                    The MAXScript option - renderers.current.system_numThreads is per scene and you can even change it before each render. To use it - once you open your scene open the MAXScript editor(F11) and type "renderers.current.system_numThreads=number_of_thr eads". So if your CPU has 16 threads you could try with a line:
                    Code:
                    renderers.current.system_numThreads=15
                    Yavor
                    Yavor Rubenov
                      WOW WOW WOW! I tried the environment variable trick and WOW that has solved a TON of huge issues for me with V-Ray 3.6! Up to using that I had nothing but problems rendering on my main workstation and usually half way through renders all my screens would go black and it would act like the video card or its driver crapped out and I would have to at the vary least restart max as if the computer didn't freeze completely, when the screens would come back then the max viewports were just grey and wouldn't display any of the geometry so I had to cross my fingers and hit save and hope for the best as I restart max and reload my scene. BUT... after finding this VRAY_NUM_THREADS trick its working FANTASTIC!! I set it to 30 of 32 threads and its been rendering just fine all morning with no hiccups or problems! Sorry for running on and on but this is very exciting lol.
                      I was surprised to see that it didn't just drop 2 threads like I expected with editing the affinity but instead it just takes overall total usage of the CPU to 95%. Im going to test with just dropping a single thread and see if that works.
                      -dave
                      Cheers,
                      -dave
                      ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
                        Many thanks Yavor,
                        Your explanations were perfect and, like Dave, I too found that the Environment Variable setting (which I reduced by just one thread) was enough to make my main computer perfectly usable. I'll keep an eye on it and will reduce the thread number again if I find it needs further adjustment.
                        Once again, thanks for your help.
                        Jez
                          Glad that helped
                          That is why setting affinity is not a good solution. When rendering by default V-Ray will create a thread for each core, Max also has more than a few threads for the UI and other things. When you set affinity for the process Windows will run all those threads only on some of the cores and when they are many they will fight for the same cores and slow each other down.
                          On the other hand when you limit just the number of the rendering threads you leave free cores for other tasks like the Max UI and etc.
                          It's good that limiting the threads helps your issues but they sound like there is indeed some kind of a problem with the system when under heavy load. Screen going black and Max viewports grey is an indication that the video driver or the video card itself had some issue. If different video card drivers don't help - there even could be some hardware issue.
                          Yavor Rubenov
                            Thanks Yavor, this seemed to fix my issue as well.
                            • #15
                              Whats the correct environment variable string then please? Somehow it dod not work for me thw last time i set it up. Thanks!
                              oh and does this apply to situatuon when spawner is ran on my machine for dr session?
                              Martin
