Loading custom vray plugin after vray plugins
  • Loading custom vray plugin after vray plugins
    So in 3dsmax 2022 vray now locates it's plugins from the ProgramData directory which seemingly get loaded after any plugins referenced in the plugin.ini file. I have a custom vray plugin which is located on a network drive that can't load because the Vray libraries haven't been loaded yet. What is the best way to load these custom plugins now. I can add a directory to the programdata directory to the plugin.ini and then it will load.
    Thanks.
    Hello,
    Sorry for the delayed reply.
    Generally in Max 2022 and further it is better to use Autodesk Application Packages and not the plugin.ini file.
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
