can I use Maxscript to change DR settings ?
  • can I use Maxscript to change DR settings ?
    Hello!
    vrayEditDRSettings() is function to open dialog , can I edit settings directly with maxscript ? like IP address or transfer missing data checkerbox ?
    The settings are saved in a text file, see the first green box here.
    The distributed rendering settings are stored in a text file called vray_dr.cfg, which is located in the 3ds Max plugcfg folder (normally, this is located in the local application data folder for the current Windows user)
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      I found it in "C:\Users\ #My user name#\AppData\Local\Autodesk\3dsMax\2023 - 64bit\ENU\en-US\plugcfg"
      Thank you so much, that is what I am looking for.
        Yeah, depending on Max version, those paths may get awfully contorted...
        Lele
        Disclaimer:
