vray save framebuffer via python maxscipt?
  • vray save framebuffer via python maxscipt?
    Hello everyone. i have a problem.
    i would like to create a maxscript with python that saves my image from vray's framebuffer.
    i have tried various ways but i have not found a working solution. Could someone please help me? I would just need the line of code that would allow me to save the render to a local folder. If it would help, the save render I would like to put it inside a compute loop of some images.
    Render and Animation - WWW.IMERGO.IT
    This docs page holds all the available parameters that can be controlled in the VFB via MaxScript. I presume your Python script can call those functions.
      thanks. i read the docs and used : rt.execute("vfbControl #clearimage") and rt.execute("vfbControl #close")​ to access to vfb methods. for render i used rt.render()
        Code:
        rt.execute("vfbControl #saveimage \"D:\MYIMAGE.JPG\"" )
        all these work as well, ofc.
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          Grazie ^Lele^. I am creating a loop to save 10 images. the problem is that even though Vray's framebuffer works, 3dsmax's framebuffer opens every time, so I have 10 framebuffer windows . is there a way to disable 3dsmaxframe buffer to open?( like normal vray render)
          thanks
            Prego!
            Max's own
            Code:
            rendShowVFB​ off
            should work, does it not?
            Lele
            Disclaimer:
              it works. Thanks again
                Just wondering, normally i save multiple image with batch render, is there anything wrong with batch render?
                Jackie Teh
                3ds Max 2023, V-Ray 7 [7.00.05 build 32980]
                  Originally posted by jackieteh View Post
                  Absolutely not.
                  It's also rather helpful to render variations, when coupled with scene states.
                  Lele
                  Disclaimer:
