How to add a string attribute using Extra Attributes for EXR Header Data.
  • How to add a string attribute using Extra Attributes for EXR Header Data.
    Hi there,
    i am using the OptionsRE as a base to create a blackbox renderelement to inject various kinds of meta data. Quite a bunch of the data i'd like to inject are strings (e.g. artist or scene file etc.)
    I tried various kinds of representing strings along the lines of the example (that only has int, float and vec4). Is there a comprehensive list of how to properly represent all the different exr attribute types? (also including matrices, box2i/f etc.)
    Regards,
    Thorsten
    If a value cannot be recognized a sequence of numbers, it will be treated as a string value. The type of the resulting attribute depends on how many numbers you have - one number is either a float or an integer attribute; two numbers are a Vec2f or Vec2i attribute, 3 numbers are either a Vec3f or a Vec3i attribute, four numbers are a Box2f or a Box2i attribute, 9 numbers are a 3x3 matrix, and 16 numbers are a 4x4 matrix.
      Got it. Had my code fubared elsewhere (had declared the corresponding VR::CharString locally...doh)
      Thanks,
      Thorsten
        Another thing, is there any easy way to access scene parameters from a VRayRenderElement? Like accessing scene nodes, camera name, filenames etc.
          You can use any 3ds Max API calls...
          Vladoi
