Getting/Setting the UI parameter "targeted" of a VRayPhysicalCamera
  • Getting/Setting the UI parameter "targeted" of a VRayPhysicalCamera
    I have an INode object which is a camera node shown as a VRayPhysicalCamera in the 3ds Max user Interface.
    I want to set the boolean parameter "targeted" as shown in the user interface.
    How can I do this using the SDK starting from the INode object?
    Regards,
    Ralf
    Something like this should work:
    Code:
    enum VRayCameraParams {
      pb_targeted=8
    INode *node=...;
    Object* obj=node->GetObjectRef()->FindBaseObject();
    IParamBlock2 *pblock=obj->GetParamBlock(0);
    if (pblock) {
      pblock->SetInt(pb_targeted, 0, TRUE);
      This code isn't building with the 3ds max 2014 SDK.
      There is no function Object::GetParamBlock(int). There is a function Object::GetParamBlock() but this returns NULL.
      How can I get this to work?
      Ralf Reichl
        There's probably some other param block function, I don't have the Max SDK in front of me right now. It might have been GetParamBlockByID() or something like that.
          There are exactly two functions in Object:
          IParamArray * Object::GetParamBlock() which returns NULL
          and
          int GetParamBlockIndex(int id) which only returns an "int".
          So it is not clear how to make your code work?
          I am relying on your help. I also haven't find any hint in the documentation.
          Ralf Reichl
            class Object derives from other classes (like Animatable), they have their own methods too. The 3ds Max SDK is located online here:
            http://usa.autodesk.com/adsk/servlet...12&id=23015025
            It's good to have it as reference anyways, as you will almost certainly need it.
              I have found the function GetParamBlockByID as you have suggested. Sorry for that. For some unknown reasons I couldn't find it at first.
              Please see my partial code below.
              I have tried for id the values 0, VRayLights::vrayLight_params.
              I have tried for paramid the values 8 and VRayLights:b_targeted.
              But all values in any combination doesn't yield the correct result and doesn't seem to work properly.
              Using VRayLights seems to be wrong anyway because it should be for lights only.
              There is no
              pb_targeted=8
              as you described below.
              What should I use for id and paramid in my code below?
              short id= ???
              IParamBlock2 * pblock = object->GetParamBlockByID(id);
              short paramid = ???
              bool value = pblock->GetInt(pb_paramid)
              Ralf Reichl
                Can you please tell me which id I have to use in Object::GetParamBlockByID and which id I have to use in IParamBlock2::GetInt to get the "targeted" parameter of a VRayPhysicalCamera?
                I couldn't find anything in the documentation about this?
                Thanks.
                Ralf Reichl
                  Hi Vlado,
                  I am relying on your help to solve this issue because the documentation and the source code doesn't help me on this.
                  Thanks a lot.
                  Ralf Reichl
