simple meshVoxel copy
  • simple meshVoxel copy
    I do have the following question:
    i have a meshvoxel v1 loaded from a .abc file. Now I need a simple copy v2 of this v1 in RAM where I can modify things like vertices later (but don't touch the original v1)
    in the vraymeshgeom sample provided I found the code to copy channel by channel and vertex by vertex and face by face from my original meshvoxel to the modified meshvoxel - this is my current working implementation.
    But probably I could get a good speed improvement when I could simply copy the original data as a stream or something.
    I tried the copy constructor the following way, but it does not work (voxel2 seems to have no data)...
    VUtils::MeshFile2 *pMesh1 = VUtils::newDefaultMeshFile2("E:\\001.ABC");
    int res = pMesh1->init("E:\\001_plg.ABC");
    pMesh1->setFramesPerSecond(25.0);
    VUtils::MeshVoxel *v1 = (pMesh1->getVoxel(1));
    VUtils::MeshVoxel v2 = VUtils::MeshVoxel(*v1);
    i use max 2015 with vray2.5.01
    thanks for the support in advance!
    regards
    Stefan
    Freelance 3D Artist
    https://www.deepframes.com
    What you are doing now is the correct approach, although you can use memcpy() to copy the data for a channel, there is no need to do it element by element.
