Chromatic Aberration in Lens Effects
  • Chromatic Aberration in Lens Effects
    Would it be lot of work to implement a post-render Chromatic Aberration effect in Lens effects panel? We usually add it in postproduction, but for quick, more realistic previews it would be as useful as bloom/glare effect. There is a diffraction parameter in Glare already, but it's a different thing. I don't find it in other render engines as well.
    Thanks,
    nl
    Do you have a good reference of an existing solution that works well for you? We might look into something like that.
      I am sure you know what chromatic aberration is from physical standpoint. The existing simplest solutions are already implemented in screen-space, real-time gpu (directx games). In the fastest, non-physical form it is a minimal shift and blur applied to a separate R or B channel that grows towards the edges. In photoshop it is just like "zoom blur" added to R channel (red fringe) and B channel (blue fringe). Three sliders (R,G,B) + effect saturation is all required. Here is an example of very simple but effective implementation in post-production software: https://www.redgiant.com/tutorial/red-giant-quicktip-1-chromatic-aberration
      Of course, actual physical abberation can be already simulated in vray: DOF bokeh or dispersion applied to a glass lens object covering 3dsmax camera, but it is an overkill. Fast abberation would conclude all interesting organic lens defects already implemented in Vray (Bitmap bokeh, vignetting, lens distortion, lens glare).
      Hope it is worth consideration,
      best
      nl
        ArionFX has a quite solid solution that also takes into accout the strength falloff towards the edges of the lens.
        http://support.randomcontrol.com/pag...171&src=search
        This would be a nice addition, along with reworked lens effects, which are already under consideration I believe.
          Or get a better camera lens - oops, wrong forum .
          Bobby Parker
          www.bobby-parker.com
          e-mail: info@bobby-parker.com
          phone: 2188206812
          My current hardware setup:
          • Ryzen 9 5900x CPU
          • 128gb Vengeance RGB Pro RAM
          • NVIDIA GeForce RTX 4090
          • ​Windows 11 Pro
            I have yet to see a lens that doesn't have any chromatic abberation. We usually get RAWs shot with incredibly expensive equipment, but you can always see some slight amount of CA in certain scenarios.
              You can download for free the VFB+ framebuffer it has chromatic aberration and a lot of other cool handy features. here is the download link http://www.scriptspot.com/3ds-max/sc...x-frame-buffer
                I'd also like to add - saving presets in one group preset - similar to a magic bullet or other plug-in's "recipes".
                www.studio2a.co
