render region where clicked
  • render region where clicked
    I saw a handy feature in houdini mantra render, and it renders the area where ever you clicked in the framebuffer.
    so you dont have to select or setup a manual render region, that also locks your ui.
    V-ray Has a handy feature in the frame buffer, called Follow Mouse.
      If you click on that button and then right-click in the image and select "Lock bucket starting point", you can also "lock" the follow point to some part of the image.
        If you right-click on that button and then click in the image, you can also "lock" the follow point to some part of the image.
        Now I never knew that Vlado.. cheers
          It's only there in the latest releases...
            Ah cool, I have to try that out!
            Kind Regards,
            Morne
              thanks i didnt know that, yet i use the older versions of vray 3.4/3.2, on my computer they seem faster, and have more control over the settings.
