Sometimes if I click the red stop button in VFB denoising isn't applied even if I have it turned on. I need to go in Render Elements and click on the Update button in order to get the denoised result which are extra unnecessary steps IMHO. Would it be possible for Vray to apply denoising when stopping a render from within the VFB?
Automatically apply denoising when stopping a render from the VFB
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
One day denoising will be unnecessary, processing speed, GPU's will all be so fast, you won't have to clean up anything, because it will be truly instant. That said, I think the problem here is not the extra unnecessary steps, but the fact that you didn't give the VFB time to apply the effect before stopping it. It's easy to tell if it's done it or not, when it shows "effectresult" in the drop down, rather than RGB etc.... Thing is turning it on, doesn't make it instant, it needs the image to reach a certain level of noise, before it is applied and stopping it prematurely and having to go into Render Elements, isn't such a hardship in my opinion.
Originally posted by andy51 View PostThat said, I think the problem here is not the extra unnecessary steps, but the fact that you didn't give the VFB time to apply the effect before stopping it. It's easy to tell if it's done it or not, when it shows "effectresult" in the drop down, rather than RGB etc....Last edited by Alex_M; 12-12-2018, 06:28 PM.Aleksandar Mitov
96GB DDR5
Post effects (denoiser and/or lens effects) are applied only on render end and on render stop and not on render cancel.
"Esc" key = cancel
"Cancel" button in render progress window = cancel
"Stop" VFB button = cancel
"Stop" button in render progress window = stopIf it was that easy, it would have already been done
Peter Matanov
Chaos
Originally posted by slizer View PostPost effects (denoiser and/or lens effects) are applied only on render end and on render stop and not on render cancel.
Originally posted by kosso_olli View Post
Why not making it "Stop" then? Would be much better!Aleksandar Mitov
96GB DDR5
