View tx textures
  • View tx textures
    After you convert a bitmap texture (.jpg, .png, etc) to a .tx file with ChaosGroup's MakeTx.exe program, and then place that .tx file into the VrayHDRI loader within the Material Editor, you cannot click on the material's Parameters/View Image button and actually see the texture. The .tx texture will show up in the small spherical material preview ball, and it will show up on in the viewport if you set the tx file to display on a material, but you cannot view the entire texture like you can a jpg or png file.
    Is this functionality something that is within ChaosGroup's scope of work or Autodesk/3dsmax's?
    Thanks,
    Matt
    Hi Matt,
    The "View image" button is relying on the 3ds Max's internal bitmap manager to display the textures.
    Alexander
    Alexander Kazandzhiev
    V-Ray for 3ds Max developer
      this might seem a silly question, but i often use the Vray Material Library as a base to start from, and then personalise the materials. Is there an option to download the assets as jpgs/pngs instead of tx files? This has been my first encounter with tx files, and I have no software that can open and thus edit them. Or is there free software that you can recommend?
      Thanks
        PS sorry if this is perhaps the wrong thread...I've been searching for quite some time and can't find any threads about editing tx files.
          You can 'open as' a tiff in P'shop and then edit and save.
          This was from another post somewhere here but I can't find it now....I just happened to remember the workflow
            Correct.
            .TX files are of the TIFF type, but with mip-maps embedded.
            Opening them as TIFF and resaving will however lose the mip-maps.
            So the ideal workflow to edit would be to open as TIFF, edit, and Save as some other non-compressed format, like PNG.
            Finally, the .TX file should be remade from the edited PNG via makeTX.exe, so to get all its benefits.
            Lele
            emanuele.lecchi@chaos.com
            Disclaimer:
              Oops, I forgot that part. Thanks for reminding me and sorry for the incomplete and possibly misleading solution
                thanks guys
                  Hello, all.
                  Also relatively new to TX files here... Will the ideal process described by Lele work throughout the VRay platforms? I'm using the Sketchup version.
                  The only reference I could locate on the Chaos sites was for Houdini
                  MakeTX - V-Ray for Houdini - Chaos Help​
                  Any help for Sketchup-specific application?
                  Thanks!
                    Originally posted by sandy_lee View Post
                    Hello, all.
                    Thanks!
                    Hello and welcome, Sandy.
                    The saving and rebuilding of the mipmaps is valid for all the V-Ray platforms, so long as you have a makeTX.exe installed.
                    I'm unsure of where it may be installed for sketchup, but you can ask in the specific forum section.
                    In case, it's in any installation of V-Ray for Max, Maya or Houdini, there's no need for licenses.
                    Lele
                    Disclaimer:
                      Oh, thanks for your quick response Lele!
                      Can you clarify this: "In case, it's in any installation of V-Ray for Max, Maya or Houdini, there's no need for licenses."
                      Does this mean that with my VRay 6 I already have access to this feature somewhere? Or just that I won't need to pay for it?
                      Appreciated.
                        Eheh, it's quicker to put it in a zip and attach it here.
                        It's the executable that is needed to be run on the images so to rebuild the mipmaps.
                        It should come with your installation, likely in a \bin folder
                        Lele
                        Disclaimer:
                          You can change the .tx file to .tiff by renaming the end of the name in your folder. For example: I renamed 3f3b04f9_Diff_4k_srgb.tx to 3f3b04f9_Diff_4k_srgb.tiff and then opened the file in photoshop.
                            Certainly doable, but there are important caveats to renaming the extension.
                            Losing the mipmaps may make a project shoot up in RAM occupation, potentially making it unrenderable on a machine it worked well with before.
                            Lele
                            Disclaimer:
                            • #15
                              could please post the location image, i cannot find \bin, thanks in advance
                              Jackie Teh
                              3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
                              AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
                              Website: https://www.sporadicstudio.com
                              Email: info@sporadicstudio.com
                              YouTube: https://www.youtube.com/c/SporadicStudio
