Vray distance txt fallof curve option
  • Vray distance txt fallof curve option
    Hi, would be very nice to be able to dictate the blending via a curve in the vray distance txt.
    I'm joining an image, to show the problem, if I had control over a curve how the blending occur, I could make it way more smooth etc.
    I hope it's possible.
    Usually, I put it inside an output map and play with the curve to get the desired transition...you can also use the "Mapped " mode inside gradient ramp and use vraydistancetex as source and re-map the values as you want( usually to add different colors/values based on the distance)
    would be cool to have these controls inside the map itself tho.
    Also, I'm not sure if you aware of that or not, but you can apply distancetex to Displace modifier and see in realtime the effect while adjusting the curves.
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
