Hi all!
I find a little strange the fact that render region option in the VFB is not useful if I have to change the resolution of my image or is the first render I do after opening 3dsmax.
I make an example: I open 3dsmax max and want to make a render of the bottom right corner of my 3000x2000px image, I open the VFB and it is grayed out since it's the first render I'm working on. I cannot use the VFB render region then I have to use the 3dsmax render region. After that render is finished I change camera, change the resolution and I use a vertical aspect like 2000x3000 and I have to render the bottom left corner. I have to use again the 3dsmax render region function.
Is there a way to be able to use the VFB in a more "dynamic" way?
An idea "maybe" is that when I click on region render in VFB I obtain a very low res image (maybe a snapshot) of the viewport rescaled to the final render image that will help me to choose the right place to region render.
This would be helpful in order to avoid to "forget" the 3dsmax render region activated
Thanks
Ale
Thanks
Ale
