Granted, physical reality is fantastic and improves yearly. But, we still need the ability to break physics to be creative. Having the option to "decay" the light in a non-physically correct way needs no reason. We just need to be able to do it.
V-Ray 6.20.06, 3ds Max (3D Studio thru Max 2025), GIGABYTE X570 AORUS Master Motherboard, Ryzen 9 3950x CPU, Noctua NH-D15S CPU Cooler, 128 GB G.SKILL Trident Z Neo DDR4 Ram, NVidia RTX 4090, Space Pilot Pro, Windows 11, Tri-Monitor, Cintiq 13HD
Autodesk Expert Elite Member
and if you indeed want to turn on 'No Decay' function , select a vray light, run a script :
$.noDecay = true
the effect comes back
While this is possible, I wouldn't recommend it. It's hidden for a reason. There were some technical aspects that made us do it, not only the physical correctness.
As for the latter there are some things in the works that might surprize you next Update (6.1) if they turn out non problematic.
Peter Matanov Chaos
Yeah, it's not good idea to change it ,
For the next update, I can't wait to try it !
