More Proxy ideas
  • More Proxy ideas
    Just a thought but a global or selected option for switching btwn bounding box and preview from file in the viewports.
    -dave
    Cheers,
    -dave
    ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
    Hi Syclone1,
    Looong time reader, first time poster....
    I hope this can be of some use. Two days ago I wrote two very simple scripts (if you want to call them that) to do just that. I have never wrote a script before. And probably never will again as I have basically no idea what I'm doing . Having said that...
    I created a button to turn all VRay proxies to a bounding box with:
    select $VRayProxy*
    $.display = 0
    $.boxmode = on
    First line selects all proxy objects that start with "VRayProxy" (the default proxy name). Second line turns them all to bounding box. Third line is the Max version of the bounding box to make the boxes wireframe so you can see through them.
    Then I created another button to turn them all back to preview by doing the opposite:
    select $VRayProxy*
    $.display = 1
    $.boxmode = off
    This is how I toggle them on and off. If someone has a better way of doing this I'm all ears....er...eyes .
    Paul
      Cool thanks Horizon Ill give it a shot, me and maxscript are like oil and water
      -dave
      Cheers,
      -dave
        A more universal one
        Code:
        objs = $objects
        for i = 1 to objs.count do
        if classof objs[i] == vrayproxy do
        	if objs[i].display == 0 then
        		(objs[i].display = 1)
        		else (objs[i].display = 0)
        That's a toggle that goes for the class, what means that you can rename them whatever you want. Also no Objects get selected.
        Toggle the state of all your proxies at once means, that it turns any proxy displayed as a mesh into box and vice versa. So to work in the way you exspect it to, all proxies should be set to one view mode in the beginning.
        that's an easy one, too:
        Code:
        objs = $objects
        	objs[i].display = 0
        You can easily turn that into a shortcut or quad entry.
        Michael
        This signature is only a temporary solution
          Thanks Sushidelic! That's great! Just ignore the junk I wrote before. Would it be possible to throw Max's "Display as Box" command in there as well? When applying VRay's "bounding box" option they show up solid which can get in the way when you've got a lot of proxies. To overcome this I apply "Display as Box" to make them show as wireframe.
          Thanks again.
          Paul
            Thanks Sushidelic, I will be trying that soon
            -dave
            Cheers,
            -dave
              The one with box mode
              Code:
              objs = $objects
              			objs[i].display = 1
              			objs[i].boxmode = off
              		else
              			objs[i].display = 0
              			objs[i].boxmode = on
              Michael
                Excellent! Thanks for taking the time Michael!
                Paul
                  Okay, these scripts don't seem to work for me....I don't think they work if you're running the N-Vida drivers for MAX.
                  The "solid box" script only affects some proxies, and when I'm in wireframe the proxies are completely invisible.
                  The "bounding box" script makes all proxies invisible.
                  Any ideas?
                    Thats a problem with the proxys themselves, not the script..
                    I'm having the same issue here on Nvidia's OpenGL, and on maxtreme 7.00.03,
                    Dave Buchhofer. // Vsaiwrk
                        Turns out it's the Maxtreme driver. Seems that is not only effects this script but the VRay Proxies themselves. If you run max without it, it seems fine.
