since it is a core feature wish I ask here and not at the silent Rhino forum.
Could it be possible to get an extra tilt correction option for the vertical direction? Good architecture photographer use lens to correct in horizontal and/or vertical direction. An example of this lenses can be found here:
https://www.the-digital-picture.com/...hift-Lens.aspx
Attached images (it's a simplified building
) shows left the standard tilt shift correction, vertical lines are straight upward. The right image shows a correction in both directions - horizontal lines are perfect kept.
Since simulating cameras is a topic for V-Ray this special lens effects should not be missed.
-Micha
-Micha
