Sliders for VrayFur maps
  • Sliders for VrayFur maps
    Please if possible can you implement 0-1 sliders for the Maps in VrayFur? or 0-100%. To allow a map to be applied only partially to the fur object (eg. I have a noise map plugged into a cellular map driving my Initial Direction map (RGB). Because it's a RGB map it's not possible for me to use midscale values of red, green or blue). Hope that makes sense!
    Thanks a mil,
    Terri
    Just mix the map with the neutral rgb color (128, 128, 255) and it should do the trick.
      Hi Vlado. This is a rather late reply! I'm not entirely sure what you mean - do you mind providing a screenshot? Do you mean to mix my noise map with a plain vray color map, or with another noise map?
      I'm doing the same thing again - except this time using a gradient map to drive it. (screenshot attached)
      thanks
        hi guys...sorry to bother but anyone else have an explanation for this? As in what map I must mix my noise/gradient map with? I'm using it on a project now. Thanks everyone!
          Does that mix map you're using not do what you need, when using white as the colour 2 and mixing between that and the colour 1 gradient?
          I think that describes the 0-100%, where white = 0. Maybe I'm incorrect but it appears to work.
          Not sure what Vlado meant tbh
            RGB 128 128 255 - blue, like blue in the normal map describing flat places. that blue as initial direction map will make fur perpendicular to the surface (plus variation from fur settings).
            mix that blue with your gradient map and you have your slider.
            Marcin Piotrowski
            youtube
            CGI OCIO config 04
              Yes that makes sense...mistakenly I used the spinners for the values, rather than via the colour swatch, which gave me the incorrect result
                Thanks Marcin. Yeah I originally created the blueish purplish colour as a mix colour. But it doesn't do anything. See attached images - mixed with 1.0, 0,5 and 0 consecutively. (Ps I'm now using a noise map to drive direction...but same same).
                I also tried mixing with white, 125 grey & black. Same thing.
                Am I missing something?
                  mix as in:
                  100% mix = blue
                  0% mix = your map
                  mix amount is your slider 0-100%
                  Marcin Piotrowski
                  youtube
                  CGI OCIO config 04
                    Originally posted by piotrus3333 View Post
                    mix as in:
                    100% mix = blue
                    0% mix = your map
                    yeah sorry if I was unclear. That's what I did. The three images are of the slider at 0 (my map fully), then 0,5 (half of my map & half blue), and 1.0 (fully blue). But it doesn't change anything.
                      are you on GPU by any chance? if so - probably Mix map not working in this case.
                      try VRayComp:
                      Marcin Piotrowski
                      youtube
                      CGI OCIO config 04
                        piotrus3333 no I'm using CPU not GPU.
                        so I switched from a mix map to a vraycomptex and now it's working. bizarre. good to know though! hope that can help others down the line. Thanks Marcin!
