Hi!
I wish VRay would provide a solution to render objects as volumes. The option to take objects as gizmos for the VRay Environment Fog is still there, i know, but using maps is terrible because of the work in world space only limitation.
A good example how it can and should simply work is the PRT Volume Object of Krakatoa:
https://docs.thinkboxsoftware.com/pr...y_volumes.html
You just pick the object and use the menue command "Create PRT Volume(s) from selected Object(s)" and a volume is generated from the selected object. Mapping and colors will be transfered directly - simple and correct - without any workarrounds.
For render you can use use the "Krakatoa Atmospheric" environment effect (https://docs.thinkboxsoftware.com/pr...ic_effect.html) - this even works well with VRay ... BUT this takes a Krakatoa License ... so rendering with the need for licenses from two different renderers at the same time seems not a good solution to me.
Even Arnold provides a solution for object based volumes:
https://docs.arnoldrenderer.com/disp...AF3DSUG/Volume
I think it's about time that VRay closes this gap.
... Should It allready be possible, then shame on me, please let me know hot to achieve it.
Thanks in advance!
Thanks in advance!
