It would be awesome if you could have V-ray toon as a renderpass. That way you could composite the lineart with shading any way you want in post. Right now you have to render several versions of your image in order to use compositing.
V-ray Toon as renderpass
You're right there is a render element already (I wasn't even aware), but it requires the atmospheric effect to be on, and the lineart still affects all the other renderelements. What I would like to see is the toon effect "only" in that render element so you could composite the toon effect. Maybe even add multiple toon elements layers with varying thickness. Sounds like that's available in Maya?
