VrayMtlConverter for BrazilMtl
  • VrayMtlConverter for BrazilMtl
    hello,
    i had buyed in TurboSquid a car. It´s has brazil material and i haven´t brazil plug-in. VrayMtlConverter doesn´t change brazil material because the brazil DLL is not. Could VrayMtlConverter change material Brazil someday?
    i had changed the brazil materials one to one... very slow.
    PD: excuseme, my english is bad, bad, baaaad!
    sorry me, I write bad english because i am spanish.
    At the moment of death I will smile
    ziddemizard,
    goto www.scriptspot.com and download VrayMtlConverter V2.0
    The new version of the converter now works with materials of any
    V-Ray versions (since 1.09.xx and including 1.46.xx)
    In this version more new function has appeared:
    - converting Brazil Advanced material into VRayMtl (testing in Brazil r/s 1.2.53)
    Chris Townsend
    Lucid Image
    www.lucidimage.com.au
      time behind i download it but it doesn´t work. Converting Brazil material into VrayMtl disable (greey). I downloaded and I installed Brazil Rio but change nothing.
        I think you must have the full version of Brazil. Maybe Splutterfish could do something about this if you write them they are usually pretty receptive.
        --Jon
          hello Trapezium,
          do you think? I don´t know if they could help me, I think Vray must can converter a material of the bibliotec it hasn´t DLL or don´t work. do you undenstand me?
            you can ask them (splutterfish) for a time-limited trial version
            they have one and it should work
              I think I understand. Bibliotec = Library?
              Well, my point is that there are distinct differences between Rio and the full Brazil that do not allow for translation between the two. I think this is where the problem is.
              I also currently use Rio but can't access that feature of the converter.
              --Jon
