Vray environment element with vray aerial perspective effect
  • Vray environment element with vray aerial perspective effect
    Hello,
    Should you guys enable an option for aerial perspective effect, to appear only on the environment render element only? The effect is very good on the rgb channel but sometimes i need to use it only on photoshop for comp afterwards. Zdepth works now and then, but the output of the aerial perspective is much better.
    Maybe a toggle to enable/disable on the final output would work.
    Tks!
    Just a correction, i was talking about "Atmosphere" render element and not "environment"
      you can just subtract the atmosphere element, and then you'll have the regular rgb beauty
      put it back by add mode, and you can set an exposure on it to make the effect more, or less, or adjust the layer opacity
      Kind Regards,
      Morne
        I´ve done a little test. I know is a workaround but it´s not the same thing as the pure rgb.
          are you rendering to EXR and keeping the PSD in 32 bit?
          Kind Regards,
          Morne
