Vray Object Properties: Select inverse
  • Vray Object Properties: Select inverse
    Please please please add an 'inverse' button in the vrayprops dialog.
    Dave Buchhofer. // Vsaiwrk
    Show a little support, I can't be the only one who uses selection sets to set up Matte passes.. cut the sets in half with one button
      Why don't you just select your selection set in the viewport. Then select inverse. Then rightclick in the viewport and click Vrayproperties. Then your selection is carried through to the Vrayproperty dialog.
      visit my developer blog
        because you have a tendency to have to set the properties on the selected object, AND set different properties on everything else in the scene..
        mabye it is just me
          since that object properties window is not modeless you'd go back and forth with it to get the set ups you need. I think just adding the same attributes you get in the normal object selection window like inverse and support for max groups would allow you to do all the work you needed in the window at once.
          V Miller
