Hi there,
I found sometimes - and especially under time-pressure conditions - that I forgot to switch off some or any of these buttons when batch rendering, or uploading them on a farm.
It would be definitely a benefit and more user-friendliness, active buttons should be more cleared out if they are still active or not...
Your mood will be in a way better condition if you don´t find your rendering sequence only rendered, where you left your last region render or got stuck by half-resolution - even you found, that the resolution was right in the Render Settings.
I can´t believe, that it would be only me getting trapped from time to time by this "issue" ... =)
(the contrast around the progression bar might also be a bit decreased for better readability.)
