Show which frame number is currently rendered (sequence rendering)
  • Show which frame number is currently rendered (sequence rendering)
    Please show which frame number is currently rendered (at sequence rendering).
    This would be often useful, when I decide to break up a test rendering earlier:
    to know, which frames were already rendered.
    Often, on the one hand, a minimum of frames is needed to see the motion
    and on the other side I'm deciding spontaneously - depending on the slow speed of rendering - when I would like to stop the rendering process.
    You mean this?
    Peter Matanov
    Chaos
      yes, I can't see it anymore. I'm always starting my render from the right teapot in the VFB, because there is always camera selection.
      when I change the viewport cameras or whatever, vray is always loosing the "fix locked" camera. which is quite poor and very annoying, too.
      I have set this a hundred times to my correct camera and locked, it never keeps the camera.
      would me my next "feature suggestion", something I'm actually expecting to be implemented.
Name:	never keeping the camera.png
        Have you tried expanding the window?
        Peter Matanov
        Chaos
          Ah, how could I know that there is something hidden
            ... open your mind and you a** will follow! .. (automatically)
            this exist, since 3D Max does
            you can work on your workflow to reduce spontaneous decisions! (helped me either)
