Vray bitmap as default
  • Vray bitmap as default
    I am used to having the convenience of dragging and dropping a jpg or png directly to 3ds max slate material editor, the problem is when I do this, it just gets imported as bitmap. Is it possible to have the default behavior to be vray bitmap instead when it's dragged into the slate material editor?
    I know I can convert all bitmap to vraybitmap with the converter, but this is quite a bit more step to have them be converted at the end, and the slate editor will not update automatically either. Unless there's already a way to do this that I am not aware about.
    Yes, that would be great. I imagine this is a 3dsmax thing, but Chaos should team up with them to make it work!
