VrayHDRI Offset??
  • VrayHDRI Offset??
    Hello!
    Maybe I'm missing it but...in the standard bitmap when using spherical environment mapping the vertical offset parameter streches the map down which is usefull when using a landscape map to lower the horizon line.
    When using VrayHDRI theres no offset parameter, only rotation...you can't lower the horizon line.
    Well..you can in a still because you don't see the other side where it actually is heigher
    Any thoughts on this?
    Thanks
    Offset doesn't stretch anything it offset it, that means at the poles you would see the ground at the north pole and the sky in the south pole.
    But your right VrayHdri can't do that, but you can just use the build in hdri loader if you use max7.
    But if you HAVE to offset it you can do it in hdrshop or maybe even in Photoshop CS2.
    /Thomas
    www.suurland.com
    www.cg-source.com
    www.hdri-locations.com
      Thanks Thomas
      Yes...it offsets it but then adjusting tilling it'll give the same effect
      Unfortunatly I'm still with max6...can I use bitmap??
      It accepts HDRI's but...tried to put it as envirenment map and just got black
      Must try photoshop though
