QOL for V-Ray Bitmap to VRayBitmap converter
  • QOL for V-Ray Bitmap to VRayBitmap converter
    Would it be possible to get more control over this feature for those of us working in ACES?
    I end up having to change the color space transfer function and the RGB color space for each image map on my materials after using the converter for each image.
    It would be wonderful if I could make a global setting to the bitmap converter for diffuse maps to be set to Type: From 3ds Max for the color space transfer function (it defaults to inverse gamma) and sRGB primaries for the RGB color space parameters (it defaults to default).
    Normal maps to be set to Type: None for the space transfer function (it defaults to inverse gamma) and RAW for the RGB color space parameters (it defaults to default).
    For the rest of the data maps to Type: From 3ds Max for the space transfer function (it defaults to inverse gamma) and RAW for the RGB color space parameters (it defaults to default).
    Renaming the image library files to circumvent all of this is not an option for us.
    Hope I was able to explain this well enough.
