viewport lights.
    Originally posted by houourin View Post
    I see, thank you.
    I had to come back to this topic because I just discovered that the "skylight" dome light does exactly what I was expecting from the Vray Dome it actually lits the scene like "enviroment map" does.
    But it is object controlled.
    Is that hard coded in a way that you guys can not use it for VrayDome?
    No it's not but it will override the viewport representation that people set up in the environment slot, meaning that it will break people's scenes. Also with just Skylight you don't get the reflections that appear when using the same map in the env slot.
    Peter Matanov
    Chaos
