Select objects by material/map caussing problems in Log
Hi
Is there a possibility that we could select the objects that the Log has identified its material/map as problematic? Like in Corona?
I use an script that searchs all material/map and there I can select those objects but it could be better if we can do it direclty from the Log
Hi, thanks for posting. From what I know the Corona log is constructed a lot differently compared to V-Ray's. I will check with the devs if your idea is possible and get back to the thread.
