IPR options for V-Ray 3dsMax
  • IPR options for V-Ray 3dsMax
    Please make the IPR option in V-Ray 3dsMax equivalent to V-Ray Maya.
    In 3dsMax, is Progressive RPP enabled and Undersampling 4?
    Can this parameter be adjusted?
    Also, please add an option like Chaos Corona 12, Update 1 to quadruple performance (1/4 size IPR) in combination with NVDIA Upscaling.
    I've also added it to the V-Ray Ideas Portal.
    https://chaosvray.ideas.aha.io/ideas/VRAYMAX-I-91​
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Hello,
    In general progressive rpp and undersampling are advanced parameters and in most cases their defaults are good enough. Can you share use cases where changes are needed ?
    The upscaling option is already available for quite a while in the VRayDenoiser RE settings.
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
