separate reflect & refract overrides
  • separate reflect & refract overrides
    it would be great if the reflection/refraction override (both in the global, as well as in the local material specific) were broken up into two separate overrides, one for reflection and the other for refraction. I have come across several instances where this would be desirable.
    www.DanielBuck.net - www.My46Willys.com - www.33Chevy.net - www.DNSFail.com
    second that!
    This signature is only a temporary solution
      yoop third that
      Tom
        and on those same lines (actually, I'm not sure that this is possible...) if there would be some sort of reflection/refraction exclude, where you could pick which objects get reflected/refracted in a particular material or object. If it's possible, it would be awesome
