Layer man: add vray prop to right click + add alternate mat?
  • Layer man: add vray prop to right click + add alternate mat?
    I wonder if it's possible to add the vray object properties dialogue to the layer manager when you right click a layer or object in layer manager. Is this scriptable?
    And wouldn't it be nice to add an alternate material column to the layer manager with a checkbox next to it to enable / disable, where you could drag and drop materials to / from the material editor. This way you could setup a default layer<->vray material structure. Is this scriptable, or do you need the sdk?
    Thanks,
    Ivan
    Just use the onion i'd say and modify it to suite your needs.
    Thorsten
      Where do I find the onion?
      I downloaded WkLayerManagerV3.70B from scriptspot and thought that was the onion?
        theOnion is great, you can get it here: http://www.blur.com/Tech/zip/theonion.zip and dont forget to download the blurLib from scriptspot.com.
        www.short-cuts.de
          thanks, installed it, now hope I can make it work with vray properties, any advice?
