An advanced Gradient Ramp which allows you to individually specify the materials within the ramp - for instance something that goes from a diffuse material to glass.
VrayGradient Ramp
VrayGradient Ramp
Tags: None
Originally posted by studioDIMIt does work by using vray colours as maps within the gradient, and as instinct said, a gradient plus a blend mat gives just the ability to fade entire materials instead of maps.
Lele
nikki Candelero.:: FREE Your MINDs, LIVE Your IDEAS ::.
by adding vray color textures
Also, you probably can work around with the blend material but it would be nice if there was an easier way.
did you double click on the little swatch arrow on the gradient ramp?
yeah - that only brings up the max swatches - I'd like it to bring up vraymaterials (basically acting as a sub-mat blend.)
you seem to miss where the gradient goes: in a vray blend material BLEND slot, not as the father of the submats.
The other, separate, issue is with HDR gradients. It could be done with standard max output maps before, but with vray color maps is a LOT more straightforward and compact.
Lele
I'm not talking about the Vray Blend Material however - refering to a separate material that would be similar to the Gradient Ramp material which allows you to choose vray materials where the arrows would be (instead of color swatches)...
I'm sure Vray Blend Material could be an alternate workaround to this - but it would be nice to have the Gradient Ramp controls/slider (if possible.)
well the gradeint ramp is a map not a material....and erm...it does just that out of the box
Doubleclicking a colour flag opens the colour chooser, but via right click on a flag -> edit properties you can assign any max map to a flag. you can mix colours and textures, or textures only etc...am i missing something ?
Thorsten
Sorry,,,but then i entirely miss the point....having a Material that has Materials stored in a gradient ramps“ flags sounds pretty...erm...well.."complex" to use and tweak...let alone proper mapping etc, it would be pretty hard to tell wich flag has what mat, and what happens to flags that dont have a mat assigned ? Solid colour.... okay...off to a birthdayparty...am seriously confused anyways lol
Thorsten
Hmm. Someone mentioned a 'blend material' and the thread went in that direction I never talked about blend materials as I wasn't looking for a workaround (I generally hate workarounds.)
I never said for this to an exact copy of the gradient ramp - somethings could be similar as a starting point then improved upon.
