physical camera creation
  • physical camera creation
    when in a perspective viewport you can hit ctrl-c to create a MAX camera of the current view. Would it be possible (or is it already and I don't know) to have some kind of function that does the same thing only creates a vray physical camera?
    http://www.chaosgroup.com/forum/phpB...hysical+camera
      If you go to the perspective view, create a VRayPhysicalCamera anywhere and *then* (with the camera still selected) hit ctrl+c. This aligns the newly created camera with the current (perspective) view.
        wow. didnt knew that either. and does work with viz. many thx vlado. great
        max 9 + vray
          Searching is a great tool.. maybe you should try it
          Also this is the better link to get that script
          http://www.chaosgroup.com/forum/phpB...ic.php?t=16553
            I did search, just not hard enough I guess. I know where you're comming from though, I see the same friggin posts all the time on cgarchitect. Hey at least I'm not asking for your "lighting setup"!
            anyways..... thanks for the scripts looks like they could come in real handy.
              hahahaha so true.
              Dont forget to check that thread every so often as Lele often updates the scripts or adds new one
