It'd be nice if one could upload an existing IRmap file without hit the render button...I know if not critical and difficult to do it but it'd be nice!!!
Load Irradiance Map
this doesnt make sence; upload irmap file? where?Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
what he likely means is this: Say you have a saved irradiance map you want to add to. The only way to truly load it into memory is to choose from file, then render a frame from it, then you can choose 'add to current map' and add irradiance map info to it if you like. I also always thought it was a rather dodgy workflow.
O.k, I wish I knew more maxscript~
How then would I take this script and have it load an irr map from file (in to memory?) so I could 'incrementally add" to it as a netrender (so that I can make the final render dependent upon it) ?
Thanks,
Eric.
Thanks,
Eric.Code:f = getOpenFileName caption:"Open Irradiance Map:" \ types:"imap(*.vrmap)|*.vrmap|All|*.*|" renderers.current.loadIrradianceMap f
to make it usable in a net render you actually have to write the above as a .ms script file with your correct paths, and attach the script at the time of sending in the render dialog 'Scripts' rollout (below where you set filename.)
edit: Erics version is to select the file with a browse dialog, to use in the net render you would include in the .ms file vlado's versionDave Buchhofer. // Vsaiwrk
