Max Hair and fur
  • Max Hair and fur
    Is it possible that a future realease supports Max hair and fur?
    __________________________
    Julien Marpault
    Artistic Director
    EDGE
    www.edge-fr.com
    Unfortunately this does not depend on us; we have no problems to support them, but Autodesk must provide access to it from the 3ds Max API.
      And they are not allright for this?
      They made for Mental ray. It will be very cool they do for Vray.
      It will be usefull.
      Julien Marpault
      Artistic Director
      EDGE
      www.edge-fr.com
        Hi Vlado what is the latest on this? Still the same?
        Kind Regards,
        Morne
          I know Joe Alter worked recently on this; I've seen pictures of it working, but I don't know what are the plans on that.
            on this ?
            on the fact that hair and fur would be bridged to vray ?
            3LP Team
              On rendering hair and fur from the Shave&Haircut engine directly with V-Ray inside 3ds Max. I do not know if this was designed for the 3ds Max Hair and Fur specifically though - it might be better to ask them directly.
                Just wondering about something:
                I have one file where I was playing with Max H&Fur and it renders with Vray no problem, in buffer mode. In another file where I'm trying it the only way it renders is geometry mode - which I think is the expected behaviour.
                I cannot figure out what I have done differently between the files though. What would allow me to use buffer in one file and not the other? Buffer certainly seems faster.
                Thanks in advance
                b
                Brett Simms
                www.heavyartillery.com
                e: brett@heavyartillery.com
                  Not sure without seeing the scenes really...
                    I will email them to you shortly then.
                    b
                    Brett Simms
                      A couple of factors that I have found that may help, although they are probably well known already: buffer H&F only works with the Max framebuffer, and does not work with crop renders. Also doesn't seem to work with VRay shadows (works, but no shadows cast or received by the H&F)
                      b
                      Brett Simms
                        Vlado do you have contact details for Joe please?
                        Kind Regards,
                        Morne
