vertical shift auto key
  • vertical shift auto key
    The common way I render a bunch of frames over night is to set up my "animation" and then render specific frames over the course of time. It would be cool, if at those specific frames you you add the vertical shift mod to each of those frames and have it stick. Or maybe there is already something like that....But anyways it would be cool.
    Thanx
    Eric Camper
    Studio 3D
    www.dbfinc.com/studio3d
    Couldn't you just animate the vertical shift?
    Dan Brew
      that's what I tried, but it doesn't hold. I turn on Auto Key and then change it at each frame I want and it stays the same.
      Eric Camper
      Studio 3D
        That's odd because it works here in Max. Are you using Max or Viz?
        Dan Brew
          Here's a copy of the track view.
          Dan Brew
            Hmmm...perhaps I am doing it wrong. I am pressing the AutoKey and it turns red. Then I go to the frame that I want and hit Guess Vertical Shift...then O move on to the next frame and etc. Weird. Thanx for your help.
            Eric Camper
            Studio 3D
              nop.. i have same problem.. with Max native camera (camera correction modifier) work's well... with Vray camera, some times, reset to the 1st frame vertical shift value ..
              Nicolau Pais www.id3d.pt
              My current hardware setup: HP Z820 32-Core Dual E5-2670 128GB RAM - NVIDIA® RTX 3060
                We have manage to resolve this by inputing the value of vertical shift at each keyframe, not using "guess vertical shift" and it does animate.
                João Grilo
                Dreamlab
                Johnny Grilo
                http://www.square-zero-one.com/
                https://www.facebook.com/squarezeroone
                  You can always use guess vertical shift then SHIFT and RIGHT CLICK the spiiner that should set a keyframe (even without autokey)
                    Hmm that's cool, I did not know that one.
                    Eric Boer
                    Dev
                      See im not just a pretty...high post count
                      It is an extremely handy tip, make its easy to keyframe almost anything with ease.
                        lol, I don't remember ever calling you pretty
                        Eric Boer
                        Dev
                          Would it work if we made the "Guess vertical shift" button actually a check-button, that, when activated, would force 2-point perspective no matter the position of the camera (rather than just calculating the value once and entering it into the numeric field)?
                            Absolutely...............that would be perfect!
                            • #15
                              yes, i guess that would be the best option afaik.
                              Nuno de Castro
                              www.ene-digital.com
                              nuno@ene-digital.com
                              00351 917593145
