Spinner reset to default values
  • Spinner reset to default values
    I think it could be useful to have VRay to reset to its default values instead of zero (Max default) after right clicking on each spinner, is it possible or that features is hard coded into Max?
    Alessandro
    This seems to be hard-coded into 3ds Max UI. Hopefully they will correct it at some point.
      I have no idea how he does it or why it's different, but the ivy generator plugin from guruware (http://www.guruware.at/main/index.html) has the right click reset it to the default values. This is the only time I have seen that a spinner does this (in my limited experience). It does come in quite handy when experimenting.
        It is certainly not impossible to implement, but requires some not so graceful work-arounds.
          I'd also like to see something like that happen.
          I'd suggest:
          Right click goes to 0, because that's how it's been for years.
          CTRL + RC resets to default
          SHIFT + RC goes to the maximum value for that spinner.
          What do you think?
          Cheers,
          Olly
          Set V-Ray class properties en masse with the VMC script
          Follow me for script updates: @ollyspolys
