Object selective sample count multiplier
  • Object selective sample count multiplier
    Not sure if this is feasbile, but I thought it may be a good idea to have a multiplier of some kind in the vray rollout of the object that adjusts the amount of samples calculated for that specific object. This way you could manually adjust the samples for more detailed geometry whilst keeping the samples for larger/none detailed objects fairly low. Thus having more control of render time.
    Regards
    Steve
    My Portfolio
    Not sure if this is feasible either, but it would be great for a situation I had today. I had this bathroom render going, and it was speeding through 90% of it, then it hit the crystal chandelier. Oh boy. I ended up cancelling it, tweaking settings and just using the mouse to render the buckets on the chandelier.
      Yes, would be great !!!
      My Flickr
        I'm lost here.
        What sampling are you referring to?
        If it's GI, that's already there with IRMap (it's very adaptive, just choose a low enough min rate), if it's not (chandelier meaning glossy reflections/refractions) that's driveable through the material itself.
        as i said, i'm confused...
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          Im talking about the gi sample count...I did say, if this is feasible. I know that this would not be a material option for reflective/refractive parameters. I was thinking it would be better to have control over individual objects gi sample count rather than having to apply an overall solution using the Irr map controls. Surely that would give more control over smaller areas ? I may way off here as I dont understand the mechanics of vray completely.
          Regards
          Steve
          My Portfolio
            Originally posted by ^Lele^ View Post
            I'm lost here.
            I was whishing for glossy reflections/refractions
            My Flickr
              Isn't the speed and quality of glossy reflections/refractions already controlled individually per material by the subdivisions and the use of interpolation in the VRayMtl Basic parameters
                I was just talking about GI sampling.
                Regards
                Steve
                My Portfolio
                  It can probably be done for the GI, perhaps in the Object settings and/or the material wrapper... I'll have to think about it.
                    I think he may have been talking about AA - i'm not sure. Like if you added an option for Max AA Samples in VRay Properties and VRayMtlWrapper.
                      Something similar to shading rate per object in RenderMan ? This would be very nice.
                      http://mikebracken.cgsociety.org/gallery/
                        V-Ray is not a micropolygon renderer, so this is not possible in the same way.
