select rendering
  • select rendering
    hey i am some what of a clumsy person sometimes when i am trying to meet a deadline and under a lot of presure
    one of my big mistake is sometime i don't apply a material to an object or i apply the wrong material to the wrong object
    i was hooping to see some sort of post fix for vray sort like fry render swap
    if not better
    or having the option to only re-render the one object that need to be fix
    also some new update to the vfb
    on the vfb their could be a slider to controlled some preset rendering setting sort of like from test--------normal--------high quality
    ((sure not all computer are the same but these could be basic settings))
    more option like the 3d max fb
    I must admit I envy MentalRay for the wonderful "render Subset of Scene/Masking" lens shader which does exactly this: it has a built-in object list and only these (or only a mask) are rendered with perfect (no opacities) occluded portions where the other objects are.
    It#s a huge time saver for rapidly changing jobs, not only for clumsy mistakes.
    Valentin
    ...forget Warp 9, engine-room please switch to Vray-speed...
