I am a total hack with mxs. I made this to update the paths of my elements to match the main output path. I don't have time right now but something similar could be made to number the output filenames.
Code:
global theRenderFile = rendOutputFilename --gets the render output path and file name and stores it in the variable "theRenderFile" global theRenderPath = getfileNamePath theRenderFile --strips out just the path part of "theRenderFile" from above and stores it in the variable "theRenderPath" makeDir (theRenderPath +@"elements\") -- makes a directory in "theRenderPath" called "elements" global re = maxOps.GetCurRenderElementMgr() -- creates a MixinInterface for the Render Element Manager. Basically creates a temporary maxscript interface into this tab in the Render Setup dialog. for i in 0 to (re.numrenderelements()-1) do --starts a loop that will repeat as many times as there are Render Elements. The zero and -1 are an offset. Some lists of things are zero based, as in, the first element in the list is 0, the second is 1, the third is 2... ( theFile = re.GetRenderElementFilename i --get the file name and path of the Render Element output path. Variable "i" will change each time the loop is run; from 0 to 1 to 2 to 3 to 4... theFileName = fileNameFromPath theFile --strip out just the filename part of the path in the last step theFile = (theRenderPath +@"elements\"+ theFileName ) -- create a new path and filename variable that uses the Render Output path plus the "elements" folder plus the original name of the Render Element. re.SetRenderElementFilename i theFile --set the output path and filename of teh Render Element to our new path variable from the last step. )
