I assume that you are talking about the features as contained in the VRayOverrideMtl. If so, I agree and would like to add to your wish a GI override material slot. Then for good measure a shadow override could be added and we would have all of the features of the VRayOverrideMtl available as Global Switches. If possible, it would be nice to also have specific include/exclude list for each override also.
Perhaps these features could be removed from Global Switches and moved into the "Environment" group to avoid clutter in the Global Switches group.
If you were not talking about per material reflection/refraction settings, then you are probably just wanting to override the environment that is being reflected/refracted, this exists in the above mentioned "Environment" group as seen here.
It can also be done per material using the "Environment" slot contained in the VRayMtl.
I need this button in for example such case:
I need to create fast preview of the animation (Reflection/refraction - off) - but i need only one of the buildings glass be in action.
So override list will be very helpfull.
Reason: add fetails
