OpenEXR Support
  • OpenEXR Support
    Splutterfish releases MaxOpenEXR 0.9 !
    It's like HDRI and offers a great new way in rendering.
    The Source code is open and download able under:
    www.openexr.org
    There you find examples and a PHOTOSHOP Plugin!
    I think this will be a standart in the future. And ILM already use it.
    Any hope Vray will support it in the future? I tried the MAX Plugin but it didn't worked with Vray.
    regards,
    robert
    I'm registed believe me! Just miss that logo.
    and here is the link to the max plugin:
    http://www.splutterfish.com/sf/downl...EXR_v0.9.0.zip
      What do you mean it doesn't work in VRay?
      Just rendered this test, seems to work great so far:
      Torgeir Holm | www.netronfilm.com
        Worked great for me too! , there is a photoshop plugin now too, Does any one know of any images available for download( other than the samples)? When rendering to a EXR does max save extended light values? or does it always clamp them?
        Eric Boer
        Dev
          The entire sachform collection is available as EXR (my testrendering above uses an image from their collection)
          http://www.sachform.de
            Also, anybody heard of a windows based program to create them or do I need to get my linux machine running again? :P
            Eric Boer
            Dev
              Ok delete that topic. It didn't work for me... but maybe I have a bad week or so...
              Well, next week I will start testing it again...
              robert
                well it seams that using the default MAX scanline renderer extra lighting data are correctly saved into *.exr image.
                But when I use VRay render, then the exr image is 100% black
                This could be realy usefull if we could use the IO plugin with Vray to generate our own HDRI / OpenEXR image.
                  V-Ray Saves out to exr fine for me , 128 bit doesn't seem to work, did you change this between renders?
                  Eric Boer
                  Dev
                    yes it works now
                    I have generated one exr mirror ball image :
                    http://www.visites-3d.com/demos/vr/5.exr
                    that gives those results when you use it with enviroment map :
                      whats the mat setting on that wood floor you have there?
                      me like a lot
                      5 years and counting.
                        me like a lot
                        simply 100% white reflect / 0.67 glossiness/ 30 subdivis / fresnel on
                        and of course a wood bitmap in the diffuse slot.
                          Ok it works now!
                          The first images where all black, but I increased the exponent it look ok now.
                          ONLY ONE PROPLEM! How to open it in Photoshop?
                          I always get an error when trying it, are there any special settings needed?
                          Hope there will be more tools soon that support this format....
                          robert
                            forget this, I found out that you have to store it in 24 bit mode... Else it doesn't work
                            robert
