Inversed Region Render
  • Inversed Region Render
    An inversed region render would be great.
    Daniel
    www.danieljhatton.com
    Inversed in what way?
      I think in this way.
      You set a region like a normal render region but you want to render all outside the region you create not the area inside.
        +1 on that
          Thats the one. It could be good for rendering building in a tree heavy scene. You could region render your subject with high settings then invert it for your trees on a low setting. This is just one example, but it could be a very useful option. Same as inverting a selection in Photoshop.
          Daniel
            Then, ad 'multi region' ... draw severals rectangle region to render ...
              I'd even add on this one, and say it would be great just to re-render a certain objects boundary...
              i.e. have an object selected and have an option just to re-render the single object while keeping everything else in vray frame buffer memory or alike..
